clamAV virus database
gretor
Post by gretor »
the virus database of clam on AV is very outdated on terra master. The update function does not seem to work. Is there any way to trigger the definition update again ? Maybe via SSH or so ?
greetings
gretor.
P.S. The old forum posts from 2020 with the same problem didn't really help me.
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
Re: clamAV virus database
Please refer to the following steps.
1. Log in to the SSH terminal
2. Edit the freshclam.conf
vi /etc/freshclam.conf
3. Replace the contents of freshclam.conf with the following and save
DatabaseDirectory  /usr/local/share/clamav/
UpdateLogFile /var/log/freshclam.log
LogFileMaxSize 2M
PidFile /var/run/freshclam.pid
Checks 12
#DatabaseOwner clamav
DatabaseMirror db.local.clamav.net
DatabaseMirror db.ch.clamav.net
DatabaseMirror db.cn.clamav.net
DatabaseMirror db.jp.clamav.net
DatabaseMirror db.us.clamav.net
DatabaseMirror db.uk.clamav.net
DatabaseMirror database.clamav.net
4.
freshclam --user=root
If it doesn't work, you can wait for the update, which will be updated recently.
PriestyUK
Post by PriestyUK »
Can anyone tell me what i'm doing wrong as ClamAV still doesnt want to update even though I have done what was said? Do I need to reboot before running the freshclam --user=root command?
crisisacting
Post by crisisacting »
PriestyUK wrote: 12 Jun 2022, 19:22 Can anyone tell me what i'm doing wrong as ClamAV still doesnt want to update even though I have done what was said? Do I need to reboot before running the freshclam --user=root command?
That version is End of Life & blocked from updating: https://blog.clamav.net/2021/12/reminde ... e.html?m=1
PriestyUK
Post by PriestyUK »
O dam.... what now :roll:
crisisacting
PriestyUK wrote: 13 Jun 2022, 00:46 O dam.... what now :roll:
One would need to independently build a newer tpk for installation, since Terra-Master has not kept their official package, from their integrated repository, current.
PriestyUK
Post by PriestyUK »
Well they should bloody well get on with it :roll:
Return to “Others”
