[ Akaunting ] Free, open-source, accounting software for small businesses and freelancers.
About: https://akaunting.com/
Category: office
Applicable TOS6: 6.0.420 or later versions
Applicable TOS7: 7.0.0420 or later versions
App download: https://tmnascommunity.eu/download/akaunting
TOS6 & TOS7: click on Support & Help from app description inside the App Center
Free
That's right, completely free. There is no limited or trial version, only full. No hidden charges or setup fees. No counter. Free means free.
Open Source
As we talk about your financials, you must be sure that data is in safe and software doesn't abuse them. Open Source software provides you full privacy.
Feature Rich
Everything you need to manage your web accounting. Keep track of all of your payments, invoices, expenses, etc. in one place with zero fees.
zicarbKK
Re: [ Akaunting ] Free, open-source, accounting software for small businesses and freelancers.
Post by zicarbKK »
Do you have a documentation about how to set up this software on Tnas?
1. Make sure you have the minimum version of all dependencies installed
apache24 > 2.4.54.1
MariaDB > 10.4.25.0
PHP81_okm > 8.1.13.1
2. Create a mySQL database for akaunting using the phpMyAdmin (follow this guide as example How to create a database using phpMyAdmin)
3. Launch the Akaunting app and complete the config
For more info to use the app, read their docs https://akaunting.com/docs
Available now and TOS7 also
