All New CloudSync
All New CloudSync
CloudSync is a cloud drive synchronization application for fast and secure data synchronization between your TNAS and cloud drives. It is a very practical and efficient one-stop cloud drive disaster recovery solution.
Different from previous versions, in TOS 5, we have integrated the synchronization of various cloud drives into one application, which is more convenient for users to use. At the same time, we have also redesigned the application layout, added some features, and optimized the user experience.
Support multiple cloud drives
CloudSync integrates a variety of mainstream cloud drive synchronization functions in one application, including Google Drive, OneDrive, Amazon S3, Dropbox, Baidu, Alibaba Cloud, etc. It only needs to manage one application to meet different cloud drive synchronization management.
Multiple synchronization strategies
CloudSync provides users with two-way and one-way synchronization strategies. Two-way synchronization can meet the flexible needs of data utilization, and one-way synchronization can meet the focus of data protection and increase data security.
Data leakage prevention strategy
In order to improve the protection of sensitive data, CloudSync supports data encryption. You can encrypt the data before synchronizing it to the cloud drive, and then decrypt the data after synchronizing it back to TNAS to prevent data leakage on the cloud drive.
Scheduled Tasks
According to usage scenarios and business requirements, users can set the execution time of synchronization tasks by themselves to avoid the busy time of business operation.
more flexible configuration
In order to meet more customer needs, CloudSync also supports various flexible configurations such as synchronization bandwidth limit, file size limit, synchronization file type limit, synchronization frequency, etc.
In full control
CloudSync not only provides users with a detailed synchronization task configuration history, but also provides a list of millions of file backups and transfers, allowing you to monitor the backup progress and various exceptions throughout the process.
villarejo
Re: All New CloudSync
Post by villarejo »
thanks for the information, but I have a question, is there a way to sync full account?
I tried both Drive and Dropbox and I'm only allowed to sync folder by folder, not the whole account.
Thanks for the help
villarejo
Post by villarejo »
Hello again,
I just wanted to add more info about this topic.
I went into de NAS via SSH and tested a cuple of commands, and it's posible to do it with a command like this one:
/Volume1/@apps/CloudSync/bin/cloudsyncd -p task_name: -m 0M -d -r MyDriveAccount:/ -l /Volume2/myPath/Drive -t 10
It would be usefull if we could config this from the web instead of this tricky way... It's not hard to set it up in the crontab, but I would prefere to not to do that way
yak983
Post by yak983 »
it's possible add in the app the follow flag?
--drive-acknowledge-abuse
Failed to copy: failed to open source object: open file failed: Use the --drive-acknowledge-abuse flag to download this file: googleapi: Error 403: This file has been identified as malware or spam and cannot be downloaded., cannotDownloadAbusiveFile
JTalbertPhoto
Post by JTalbertPhoto »
I am new to TOS and so far love it.
Out of all the NAS companies out there, I picked Terra-Master because I have had a 5 bad DAS for a few years and love it.
I was looking at TOS and features and one thing that is listed and even is mentioned in the TOS 5 instructions is the compatibility with BackBlaze. I do not see the app, and searching the forum I had seen a comment from someone from a while ago saying the BackBlaze app had not been updated in a while.
Are you all working on an updated version of BackBlaze app for TOS5?
Thanks/
yak983
Post by yak983 »
after CloudSync update to 2.2.4 version i have lost all my task and configuration.. why?
yak983 wrote: ↑30 Jun 2022, 01:10 Hello,
It will be fixed soon.
yak983
Post by yak983 »
CloudSync version 2.2.4 now i can't create new task, the app don't list a local subfolder
connector: googledrive
the local folder select remain in loading of subdirectory so i cant select it
JTalbertPhoto
What about the app? Is there going to be a separate app, or will this be integrated into the new cloud sync feature?
Thank you.
TWlhq
Post by TWlhq »
yak983 wrote: ↑30 Jun 2022, 21:23 CloudSync version 2.2.4 now i can't create new task, the app don't list a local subfolder
This issue will be fixed in next update.
