TerraSync
TerraSync
TerraSync is a cloud drive service application that helps users build their own private cloud drive services with their TNAS devices. By setting a synchronization policy, you can achieve file synchronization between TNAS and TNAS, TNAS and Windows computers, TNAS and macOS computers, and TNAS and iOS/Android mobile devices. Use TNAS to set up your own private cloud drive, an autonomous, independent, secure and economical private cloud drive.
Self-management
TerraSync Server is the leading application of the TerraSync cloud drive service. It is used to configure synchronization folders and synchronization policies, and manage file versions and permissions. The application runs on TNAS server and needs to be used with TerraSync Client, TerraSync Windows, TerraSync mac, TerraSync iOS/Android client to achieve file synchronization between TNAS and different devices.
Supports multiple clients
The TerraSync synchronization service supports many common clients such as TNAS, Windows computers, macOS computers, iOS/Android mobile devices. TerraSync can meet the cloud drive needs of home and business users.
Smart and efficient synchronization strategy
By monitoring the status of folders and files, the TerraSync client can detect the status of files in time and compare with the server to quickly complete the synchronization of newly added or modified files.
Historical version restore management
TerraSync Server has the function of managing historical versions of synchronized files and backup files. When users accidentally delete data or disasters occur, users can find historical version records through the client and select the appropriate version to restore.
Team cooperation
By configuring personal folders and team folders, users can establish a team collaboration group while protecting private data, and assign permissions to group members, so that group members can collaborate to complete the same work. TerraSync can help teams achieve the purpose of file sharing and collaboration to improve teamwork efficiency.
Computer directory backup
In addition, to file synchronization, TerraSync's desktop clients for Windows and macOS also have computer directory backup capabilities. Through the desktop client, users can back up specified folders in the computer to your TNAS. When a user accidentally deletes data or a disaster occurs, the user can find historical version records through the client and select a suitable version to restore.
Data Security
Taking data security into full consideration, when performing backup tasks or synchronization tasks between TerraSync clients and servers, SSL certificates are used to encrypt the entire process to ensure the security of data transmission. Users can also import and configure trusted digital certificates independently.
In full control
TerraSync not only provides users with a detailed backup and restore task configuration history, but also provides a list of millions of file backup and transfer records, allowing you to monitor the backup progress and detect abnormalities in time.
Suitable for a variety of applications
TerraSync is not only suitable for home users, but also for business users with multiple offices or branches. Team sharing through TerraSync improves team collaboration efficiency.
Roccia7
Italy
Re: TerraSync
Post by Roccia7 »
Hello TMRoy, where is it possible to download terrasync for windows?
TNAS F2-220
TOS 5.0.176
Re: TerraSync
We going to release TerraSync windows client this month. Please wait.
Roccia7
Italy
Re: TerraSync
Post by Roccia7 »
Ok, thank
TNAS F2-220
TOS 5.0.176
kamacete
Re: TerraSync
Post by kamacete »
I'm trying to find the way to install the sync desktop for windows, but I can't found. Can somebody help?
and if you guys have a tutorial I would appreciate.
Thank you in advance
miji22
Re: TerraSync
Post by miji22 »
Not sure if this is a bug report or intended functionality, but any Linux hidden folder/file starting with "." are not sync'd across to the other side.
Re: TerraSync
{L_BUTTON_AT}miji22
Fixed in next version.
jgea
Re: TerraSync
Post by jgea »
Is it possible to have TerraSync with offline files? In other words, to have files on demand, so the files don't get local space but you get access to them as soon as you need them.
Thanks.
TonyM68
Re: TerraSync
Post by TonyM68 »
I'm new to using TerraMaster and have recently loaded TerraMaster Sync. Where can I download TerraSync mac and windows? I've searched online and within this forum and have not been able to find any. Thank you for your products.
Re: TerraSync
The PC client has not yet been released.
