went from 4.2.27 -> 4.2.32 SMB sharing doesn't work with windows 10
Overclocked
Post by Overclocked »
After The update im getting error codes when trying to send a file from my windows 10 pc to the external drives plugged into the F2-420 NAS.This happens specifically when transferring from/to the external usb drive i have plugged into the nas. When i try sending/receiving to the onboard NAS 2 drives it works without a problem. Plex on another unite still reads the files on the external drive just fine. Whats happening ? i have tried everything.
Re: went from 4.2.27 -> 4.2.32 SMB sharing doesn't work with windows 10
Can you attach the screenshot of the error?
Did the file transfer work fine until you updated the system?
Is it normal when you upload files to the USB storage device in TOS > File Manager?
gretor
Post by gretor »
Maybe the SMB settings in the Terra Master device were reset after the update. It would be important to check this and select smb 2 to smb 3 for the smb version. If SMB 1 is selected, Windows may refuse to cooperate.
greetings
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
sianderson
Post by sianderson »
TMSupport wrote: ↑19 Apr 2022, 10:02 Can you attach the screenshot of the error?
this has been highlighted before to TM that it is an issue?
viewtopic.php?f=28&t=3063
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Return to “File Services”
