Proxmox install
djtron99
Proxmox install
Post by djtron99 »
Hello, can I replace the usb inside the case and install proxmox instead?
TMnorah
Re: Proxmox install
Post by TMnorah »
Hello, if you are using an X86 model, you can replace the usb inside, but the arm model does not support it. It is recommended to use our own usb installation system to replace the system.
