Sync all contents at root level in OneDrive to Sync
jdalconchel
Post by jdalconchel »
I'm not able to select the root folder of a OneDrive folder in the cloud. Only can select a single folder, and I want to select to Sync all the OneDrive contents....
I'm using TOS 5.0.72 beta
Re: Sync all contents at root level in OneDrive to Sync
Hello, the system does not have permission to obtain the root directory, so it does not support directly selecting the root directory for backup.
Return to “CloudSync”
