F2-210 working but isn't able to do anything in web interface [502 Bad Gateway]
GianSeven
Post by GianSeven »
Hi, I bought my NAS two and an half years ago and it has been working fine since then but from about one month it gives an error if I try to open most of the settings or any app. Everything that was already configured like SMB and FTP still works fine so that's because I left it in this state for so much time.
The version is 4.2.08-2101111540 and I don't know if it matters but everytime I log-in on the web interface it asks me to update to version 4.2.31 but if I click on search for updates it says there are no updates available.
I thought it might have been the HDD but I checked it with S.M.A.R.T. and it said its ok.
This is the error it gives inside the windows:
Here's all the errors it gives on the right, some are repeated hundreds of times so I deleted some:
Warning: fopen(/tmp/file-196528271): failed to open stream: No space left on device in /usr/www/include/class/func.class.php on line 589
Warning: fwrite() expects parameter 1 to be resource, boolean given in /usr/www/include/class/func.class.php on line 607
Warning: fclose() expects parameter 1 to be resource, boolean given in /usr/www/include/class/func.class.php on line 609
Warning: copy(/tmp/file-196528271): failed to open stream: No such file or directory in /usr/www/include/class/func.class.php on line 610
Warning: fopen(/tmp/file-86306190): failed to open stream: No space left on device in /usr/www/include/class/func.class.php on line 589
Warning: fprintf() expects parameter 1 to be resource, boolean given in /usr/www/include/class/func.class.php on line 602
Warning: fprintf() expects parameter 1 to be resource, boolean given in /usr/www/include/class/func.class.php on line 600
Warning: copy(/tmp/file-86306190): failed to open stream: No such file or directory in /usr/www/include/class/func.class.php on line 610
Warning: fopen(/tmp/file-198238733): failed to open stream: No space left on device in /usr/www/include/class/func.class.php on line 589
Warning: copy(/tmp/file-198238733): failed to open stream: No such file or directory in /usr/www/include/class/func.class.php on line 610
Re: F2-210 working but isn't able to do anything in web interface [502 Bad Gateway]
From the error information you provided, some system files are corrupted, it is unclear what cause it. You may need to reinstall the TOS.
viewtopic.php?f=76&t=423
But if you are prompted to create a new RAID and volume, you need to quit the installation immediately. It is recommended to backup your data before you reinstall your TOS.
GianSeven
Post by GianSeven »
I tried backuping the system configuration as the first step of the guide recommended but I don't think it's working. When I click "Apply" it prompts me to input my password but then nothing happens, I can't find the file saved anywhere. I tried different browsers and devices but it doesn't do anything either. Could you give me an example of how is the file supposed to be named? I might have already done this and saved the file somewhere
Your file system is working abnormally now, many features may not able to work correctly, please ignore this step.
