TOS 4.2.31(ARM) is released for update
TOS 4.2.31 (ARM) Release Notes
Applicable models: F2-210, F4-210
1. Fixed vulnerabilities of login information encryption.
Important Notes
1. This update is only for TOS 4.2.01 or later versions. If your TOS is 4.1.27 or an earlier version, please refer to here.
How to update your TOS?
Online update:
1. Go to TOS > Control Panel > General settings > Software update;
2. Check the option "Online update", click "Apply";
3. Follow the prompt to finish the update;
Manual update:
1. Download the update package: Update package for ARM models
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
Issue report
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
Important Notes
Online update:
Manual update:
4. Click "Apply";
Issue report
- Saijin_Naib
Re: TOS 4.2.31(ARM) is released for update!
Thanks for the security updates!
I still would love to see the hashes posted to the forum announcements, however.
You can check the MD5 value from the download page.
https://support.terra-master.com/downlo ... uct=F2-210
- sianderson
- Silver Member
thanks, updated no issues so far
F2-424 TOS 7.0.1341
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- snapperheadjoeTM
This version also resolved the notification broken links to Control Panel issue from 4.2.30. I'm also seeing faster video load times in Emby after this update.
No Issues for me after the installation
- Jac de Lad
Updated my F2-210 without problems. No services selfactivating or something.
- firedrakes
cannot choice any other raid option
f4-210
f4-210
{L_BUTTON_AT}firedrakes
- firedrakes
i am un able to set said nas(model mention already) to any other raid mode.
lets say i got to storage pool. other then delete. everything is grey out and un clickable
