F5-221 GUI icon Update&Recovery disappear
dusank
Post by dusank »
Hi all,
I can't see GUI option Update& recovery under General settings.
Model F5-221
TOS version: 4.2.09
If I use Search option this appear : "An error occurred in the application. Please uninstall it and install it again!"
I download System report if need
Would you be able to help me anybody?
Thank you.
Re: F5-221 GUI icon Update&Recovery disappear
Hi, can you provide a specific screenshot?
dusank
Post by dusank »
Yes, please see the screenshots attached (missing Update&Recovery and also the error when I try search in settings for Update&Recovery )
I can't attached the system report, unfortunately.
Would you help me, how to upgrade the system to higher version?
Regards
Dusan
Hi, you can try refreshing the browser cache or restart TNAS to see if the problem still exists?
And please go to "Technical Support - Issues Report" to generate a log and send it to our support mail.
dusank
Post by dusank »
Hi
I clean the cache of browsers few times.
I uses Chrome/Firefox/Opera web browsers with last updates.
Also, I reboot TNAS with GUI browser soft reboot a few times.
Nothing help.
I 'll generate the system report log and send to suppor(at)terra-master.com
It's strange, because was there last week.
Only one action I did, I upgraded EMBY server.
Also I try to uninstall EMBY server, reboot TNAS, but no success.
Kind regards
Dusan
Return to “Others”
