Backups stuck at 99%
Duple Backup has powerful backup and restore functions, and is a disaster recovery tool designed to strengthen the data security of TNAS devices.
MrJack
Post by MrJack »
I tested the application to make incremental backups with compression on an external disk.
The folder to be backed up contains about ~50'000 various files for a total of 1.3TB.
The backup operation went well and apparently the data is created.
However, the backup remains blocked at 99%.
I let the application run for more than 24 hours without success.
After stopping the task, deleting the backup files and restarting it, the problem is still there.
Any idea what could be causing the problem?
Thanks in advance.
MrJack
Re: Backups stuck at 99%
USB Backup?
Please check on your external drive, how much space leave there after backup? and how many files have been copied successfully?
Return to “Duple Backup”
