When I installed the latest update of macOS Monterey, I got a dialog that the installed system extension (RAID driver) won't work with future macOS releases.
Will I still be able to use the D5 Thunderbolt 3 in the future?
macOS Monterey successor won't support RAID driver
Re: macOS Monterey successor won't support RAID driver
If your product is D5-330 Thunderbolt 3, please use RAID Manager Pro version, there will be no macOS Monterey compatibility issues.
Please confirm your model. Currently, the RAIDManager of the D5-300 model is not compatible with Mac OS Monterey. We are still developing a Monterey RAIDManager client. If the D5-300 model is used, you can run it on Mac OS10.X RAIDManager, create a RAID mode, use D5-300 on macOS Monterey.
