[ Kiwix ][ 3.2.0.0 ] Offline reader for online content
About: https://www.kiwix.org/en/
Category:
Last version: 3.2.0.0
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
App download: https://bit.ly/3yrlj5t
http(s)://yournasip:port/modules/Kiwix/www
.zim packages available at https://library.kiwix.org/?lang=eng
After app installation, connect with SSH and create the library file to add the .zim info using kiwix-manage tool
/mnt/appdata/MOD_CONFIG/Kiwix/library - is the library file which will be loaded on kiwix-serve and where the package info is stored
/mnt/appdata/MOD_CONFIG/Kiwix/archlinux_en_all_nopic_2022-03.zim - is the full location of the .zim file to be added in the library
[root@TNAS-xxxx ~]# kiwix-manage /mnt/appdata/MOD_CONFIG/Kiwix/library add /mnt/appdata/MOD_CONFIG/Kiwix/archlinux_en_all_nopic_2022-03.zim
[root@TNAS-xxxx ~]# kiwix-manage /mnt/appdata/MOD_CONFIG/Kiwix/library show
path:           /mnt/appdata/MOD_CONFIG/Kiwix/archlinux_en_all_nopic_2022-03.zim
url:
title:          ArchWiki
tags:           archlinux;_pictures:no;_videos:no;_details:yes;_ftindex:yes
description:    Arch Linux documentation
creator:        Archlinux
date:           2022-03-16
articleCount:   13555
mediaCount:     2
psikic
Re: [ Kiwix ][ 3.2.0.0 ] Offline reader for online content
Post by psikic »
Wow! So fast! Thank you again for building another great package. By the way, I clicked the PayPal donation link at the bottom of the package and I get a HTTP 403. Is there an alternate way to send you a donation to thank you?
Thanks foor feedback! I just clicked on the donation link and is working, maybe something blocked on your side ?
