Admin user question
nedhedrick
Admin user question
Post by nedhedrick »
I have defined a new admin user for security purposes. I would now like to delete or de-activate the previous admin user, but TOS will apparently not allow it. How can I delete or restrict the old admin user so it is no longer able to be used?
Thanks in advance!
Re: Admin user question
{L_BUTTON_AT}nedhedrick
Please go to Control Panel> Update&Recovery> Backup&Restore, and then reset system configuration to set a new administrator account.
nedhedrick
I have followed the instructions and reset the configuration. Device restarted with the new admin user. Then I restored my configuration so I could get to my data. The old admin user returned and still cannot be disabled or deleted! Not sure what to do at this point. My objective is to remove access to the previous admin user, because I had named it with the common name "admin". But I still am unable to do that. Any additional tips? Or is the only option to do a complete rebuild of the environment?
Thanks!
The original system configuration contains the admin user. When you restore the system configuration, the admin user will appear again.
nedhedrick
I was afraid of that. I guess the only truly secure solution is to reset the configuration and then manually re-enter everything (except the old admin user).
Too bad...
Thanks for the help anyway -- I learned a few things along the way...
Return to “Privileges”
