Do TOS Updates also update initboot?
seajayshome
Post by seajayshome »
Hi - I wanted to ask if the standard TOS updates also update the initboot USB?
When I initially installed my TNAS a couple of weeks ago it was on initboot v3.0, which I understand is quite old, however I followed the appropriate steps to install and update TOS - I was just wondering however if that will have also updated initboot, or whether I should manually update that seperately?
Re: Do TOS Updates also update initboot?
The initboot will be updated together with the OS. your initboot and system is a version very out of date, you need to update step by step by following the instruction.
Return to “Initialization”
