Following advice regarding my high CPU usage I have since factory reset my my F2-210.
Once the reset was complete I followed the advice regarding the ransomware attack and changed the settings as advised in the post. However, my TNAS is now unable to connect to the internet and is constantly showing as being disconnected
download/file.php?mode=view&id=1751
Looking through the forum I have also ensured that my Primary and Secondary DNS settings have been inputted
download/file.php?mode=view&id=1752
However, I am unable to set the default gateway. Every time I tick this option, the screen takes a while to refresh and the icon remains unticked
download/file.php?mode=view&id=1753
I have tried resetting the device, change the IP address and nothing seems to work. Any guidance would be much appreciated.
F2-210 - Internet Disconnected
- crisisacting
- Silver Member
Re: F2-210 - Internet Disconnected
Unless you actively use TNAS Mobile, the current state of disconnected is actually going to aid in the prevention of those attacks.
Otherwise, you'll likely need to reconfigure your network config through SSH to be able to retain them.
This thread has similar instructions: viewtopic.php?t=508
So I'm unable to access my Plex media serves which is what I use the TNAS for. It just keeps telling my that the device is unreachablecrisisacting wrote: ↑27 Feb 2022, 08:41 Unless you actively use TNAS Mobile, the current state of disconnected is actually going to aid in the prevention of those attacks.
The disconnected message refers to the Internet not the lan. Check your TOS firewall settings. You probably have settings enabled which are blocking all inbound connections. This is how I keep my settings 99% of the time. I only disable the Internet blocking to update TOS.
Firewall disabled, still the same. Logged out with firewall disabled and reconnected, nothing changes.titanrx8 wrote: ↑28 Feb 2022, 00:36 The disconnected message refers to the Internet not the lan. Check your TOS firewall settings. You probably have settings enabled which are blocking all inbound connections. This is how I keep my settings 99% of the time. I only disable the Internet blocking to update TOS.
{L_BUTTON_AT}rankinc
Maybe the DNS configuration file is wrong. Please refer to the article for troubleshooting: viewtopic.php?t=508To contact our team, please send email to following addresses, remember to replace (at) with @
The DNS was showing as 8.8.8.8 - I'm not an expert so I wasn't to confident in accessing SSH. The post you linked to literally made no sense to me as i have no idea what issues i could cause if i did something wrong. Anyway, it still disconnecting. All I wanted was basic plex server and i cannot access any of my media unless I disable the firewall on the machine.TMSupport wrote: ↑28 Feb 2022, 10:26 Maybe the DNS configuration file is wrong. Please refer to the article for troubleshooting: viewtopic.php?t=508
Please contact our tech team to help you troubleshoot the issue.
I have, and unfortunately they are not very helpful. they've informed me that the information posted about firewalls on this forum (regarding the ransomware thread) is incorrect and is a forbidden firewall rule, even though my NAS accepts it. They've just refused to answer my follow-up question when I posted that issue is still happening. I'm shocked at the level of technical expertise from Terramaster given personal information that people could keep on their NAS's. The whole experience is truly shocking.
Now your question is when you don't use the firewall is the network still not connected?
1. You can try to check whether the firewall is enabled on the router;
2. Insert another network port on the TNAS;
3. Insert another network port on the router;
4. Set the gateway and DNS to be the same as your computer;
5. Reinstall the system
6. Make an appointment with our technical team for a remote inspection.
