it is impossible to connect to the nas from the internet, only ftp works.
I can connect to the gui, but I can't share folders using webdav or another system.
The VPN server gives me an IP out of the 10.xxx range, if I configure it to give me 192.168.1.x it starts at 0, so it assigns me 192.168.1.1, the same as the router, it is a big mistake not being able to tell the VPN server starting at 192.168.1.30 for example.
The software has disappointed me a lot, I'm having a hard time synchronizing files outside the network, I thought I would have a simple application. Now I only have the ftp option which is very insecure and time consuming.
How do I sync folders over the internet? in local network it works well but it is not practical.
PROBLEMS I thinks it will easy!!
TMAY
Re: PROBLEMS I thinks it will easy!!
Hello, I don't quite understand what you mean, is the nas unable to connect to the Internet? Does the network light come on? Is it accessible using SMB?
