I applied the last upgrade on my TNAS yesterday and after the update my box is booting however no service is available. I can access to the port 23 of the device and can see all volumes mounted, but no other service is avaliable.
Any procedure to recover?
TNAS f2-220 accessible only by telnet after upgrade
Best regards
Luiz Rodrigues
Best regards
Luiz Rodrigues
Re: TNAS f2-220 accessible only by telnet after upgrade
Hi, you can reinstall the TOS system to fix it, please see the instructions below:
Please be advised the TOS reinstallation would not erase your data unless you encounter B below.
Power off the NAS, take out the HDD’s, power on the NAS.
Search the NAS IP address by the TNAS PC App, click on the located IP address and click "Login"
When it says no HDD detected, keep the NAS powered on and install your HDD
Next
When it asks if you’d like to install TOS already in the HDD or install new TOS, please select “Install new TOS”. And here there is a message saying the data in the hard drives would be lost, please ignore it, your data won’t be lost by confirming “Yes” to proceed here.
Next
Auto download and install TOS system (recommended)
Set your password and time zone
After that, there are two possibilities:
A. You may be directed to the log in page, please go ahead to log in.
B. You may be directed to the RAID creating page, please STOP here and close the window immediately. Please get back to us, and we will need to remote-in to check.
After the TOS reinstallation, to ensure you can see the data in your hard drives, please check the following:
1. Please ensure the admin user has the R/W permission to the shared folders.
Please go to TOS Control Panel – Privileges – User – select the user and Edit – Permission
2. Please ensure the shared folder’s R/W permission is authorized to the user:
Please go to TOS Control Panel – Privileges – Shared Folder – select the shared folder and Edit – please check in User permission and Group permission accordingly.
3. If you are still unable to see the data, please go to TOS Control Panel – Privileges – Shared Folder – Advanced – Restore to
Next
Next
The process worked perfectly, thank you.
Best regards
Luiz Rodrigues
Best regards
Luiz Rodrigues
