volume good. but drive going bad .bug mybe?
firedrakes
Post by firedrakes »
so for what ever reason the system say volume is fine etc.but after doing a bit of testing and digging.
it showing 1 of the drive is bad.
idk why the system did not warn me. i had options to get info if it happen.
so ether the system itself is going or the os update bonk it.
seeing no issue last week.(all drives where showing good.)
atm am working on getting the data off. seeing it set onto raid 0
Re: volume good. but drive going bad .bug mybe?
There are many types of hard disk failures, and not all of them affect the file system of the data partition.
Can you tell us what errors your hard drive is showing on the testing tool?
We are adding more detailed hard drive testing and reminders, it would be great to know more about you.
firedrakes
smart info. when going into looking at disk. say warning disk is bad.
i will do a bit more research on it. right now am trying to get data off of nas. so when i can i will reply again with more info. then when i posted.
firedrakes
TMRyan wrote: 23 Feb 2022, 00:26 There are many types of hard disk failures, and not all of them affect the file system of the data partition.
a update.
head went. on drive.
but again i had zero notification. on it.
when i made sure for it to send if. anything was going.
also it seems the OG set up. due to firmware hanging the prev time.
it in correctly set up a different raid.
