F4-210 Network Speed
RobL216
Post by RobL216 »
So I have the above and it is connected to my HP Managed Switch.
When looking at the the T-Nas interface in TOS it shows it is only connected at 100Mb.
I have checked the switch and when set to auto negotiate the T-NAS will only negotiate 100Mb. If I set the switch port to 1GB the T-NAS will not connect.
My understanding is that this device as a 1GB NIC but it does not seem to be so.
I have tried different cables and ports to no avail. If I connect my laptop to the same port it connects at 1GB so I know my switch and ports are working fine and also the cables.
Any thoughts why this will not connect at 1GB?
Rob
Re: F4-210 Network Speed
Hi! You can try connecting the network cable directly between the TNAS and your client computer.
Return to “Network”
