Clam antivirus for F4-210
antocara
Italy
Post by antocara »
I notced that after the last SW update with version TOS 4.2.28-2201201720, a Clam antivirus icon showed in my TOS desktop which I didn't have before. I tried to launch it byt a windows popped up telling "Your System has been updated. The application need to be updated to run in the new system". I hit the "confirm" button and the applications windows manage showed up, but there is no clam Antivirus app available in "intalled" section, in "all" section or in the "beta" section.
PLease advice on how to proceid to install Clam Antivirus manually.
Thanks,
Regards
Re: Clam antivirus for F4-210
F4-210 does not support Clam Antivirus application.
antocara
Italy
Post by antocara »
So why I have it shown on my TOS desktop if it is not supported ?
The Clam Antivirus icon showed just after TOS update !!
Return to “Others”
