Cannot access new folder under root folder in windows
renj86
Post by renj86 »
I have a Terra-Master F2-210.
I created a folder under the root folder, FolderA, in addition to the public, appdata folders under the root folder by default. FolderA is one of the Shared Folders. However, when I try to access FolderA with the admin username and password in the "Network" of windows, it always prompts the following message.
"FolderA is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again. "
I can access public folder without any issue. I can also browse the FolderA folder under TOS webpage interface. How can I fix this?
TM-Allen
Re: Cannot access new folder under root folder in windows
Post by TM-Allen »
Hello.You can edit the permissions of the shared folder and give the admin user permission.
Return to “File Services”
