Hi there, I've got a F4-210 running 4.2.28. I can install the docker app, but when I try to download an image the CPU spikes to 100% and if never actually downloads.
I've rebooted then as, uninstalled docker, deleted the appdata folder and reinstalled it, no luck.
What can I do to fix this?
F4-210 Docker issue
Re: F4-210 Docker issue
With the current level of specialists in technical support, you have done everything that you can offer. Hold on.
