TOS 4.2.28(ARM) is released for update
TOS 4.2.28 (ARM) Release Notes
Applicable models: F2-210, F4-210
This update includes the following bug fixes for the previous version and new features:
1. Added pam authentication mechanism for SSH, Telnet, AFP, and FTP;
2. Fixed the vulnerability of php encryption;
3. Fixed the issue of Windows Backup;
4. Fixed the issue of SMB password setting.
Important Notes
1. This update is only for TOS 4.2.01 or later versions. If your TOS is 4.1.27 or an earlier version, please refer to here.
How to update your TOS?
Online update:
1. Go to TOS > Control Panel > General settings > Software update;
2. Check the option "Online update", click "Apply";
3. Follow the prompt to finish the update;
Issue report
If you encounter issues during use, please report to TerraMaster's official forum “TOS update”.
Saijin_Naib
Re: TOS 4.2.28(ARM) is released for update!
Post by Saijin_Naib »
Thank you so much for moving quickly on these fixes!
Jac de Lad
Post by Jac de Lad »
I updated without problems.
sianderson
Post by sianderson »
Thank you all updated, no problems so far
Only slight criticism as always is the lack of knowing there is an update, I would imagine the majority of owners don’t read the forum, they buy, use and forget about it, people only tend to use a forum like this if they have problems
So a way for you to alert a user there is an update would be good, either by automated email or flashing a light on the front of the unit to say there is a notification to prompt someone to go and look
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
{L_BUTTON_AT}sianderson
Hi! The system update notification push on the desktop will be slightly later than the forum update release.
RedCraft
Post by RedCraft »
After the upgrade, the FTP port was reset to "default" 21! If you don't use it, disable it or change it.
f2-210
demetry14
Post by demetry14 »
Update took about 5min and changed:
RSYNC user back to rsync from previously set username.
SMB ON from previous OFF state.
DNS changed to DNS 1: 8.8.8.8, DNS 2: blank from previous static settings in both fields.
Other than that, it is up and running and can be rebooted without boot loops or long wait times before it is ready "at this time". Now I will shut it down and see if it still follows the Power On/Off Schedule I've set previous.
Demetry
F2-210
F4-210
sianderson
TMSupport wrote: 22 Jan 2022, 18:34 Hi! The system update notification push on the desktop will be slightly later than the forum update release.
Does this require someone to login? After all majority of people will set up a nas drive and then never log back into the desktop and just access the shares via a windows computer so would still be none the wiser that an update exists
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
MollyJ
Post by MollyJ »
sianderson wrote: 23 Jan 2022, 03:57
Wouldn't the option of being put on an email mailing list be possible when a new verion TOS is released? We check our emails daily and we could sign up or not sign up to such alerts. Just a thought...
vincentld
Post by vincentld »
please, could you provide download link for manual update ?
Thanks,
