[ ttyd] Share your terminal over the web
About :
Category: Tools
Applicable models:
TerraMaster x.64 series, armv8 series, armv8.2
Applicable TOS5: 5.0.163 or later versions
Applicable TOS5: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/ttyd
ttyd is a tool for sharing terminal over the web
USAGE:
    ttyd [options] <command> [<arguments...>]
VERSION:
    1.6.3
OPTIONS:
    -p, --port              Port to listen (default: 7681, use `0` for random port)
    -i, --interface         Network interface to bind (eg: eth0), or UNIX domain socket path (eg: /var/run/ttyd.sock)
    -c, --credential        Credential for Basic Authentication (format: username:password)
    -u, --uid               User id to run with
    -g, --gid               Group id to run with
    -s, --signal            Signal to send to the command when exit it (default: 1, SIGHUP)
    -a, --url-arg           Allow client to send command line arguments in URL (eg: http://localhost:7681?arg=foo&arg=bar)
    -R, --readonly          Do not allow clients to write to the TTY
    -t, --client-option     Send option to client (format: key=value), repeat to add more options
    -T, --terminal-type     Terminal type to report, default: xterm-256color
    -O, --check-origin      Do not allow websocket connection from different origin
    -m, --max-clients       Maximum clients to support (default: 0, no limit)
    -o, --once              Accept only one client and exit on disconnection
    -B, --browser           Open terminal with the default system browser
    -I, --index             Custom index.html path
    -b, --base-path         Expected base path for requests coming from a reverse proxy (eg: /mounted/here, max length: 128)
    -P, --ping-interval     Websocket ping interval(sec) (default: 300)
    -6, --ipv6              Enable IPv6 support
    -S, --ssl               Enable SSL
    -C, --ssl-cert          SSL certificate file path
    -K, --ssl-key           SSL key file path
    -A, --ssl-ca            SSL CA file path for client certificate verification
    -d, --debug             Set log level (default: 7)
    -v, --version           Print the version and exit
    -h, --help              Print this text and exit
Visit https://github.com/tsl0922/ttyd to get more information and report bugs.
additional security layer can be done by adding a basic authentification for the access page, using option -c username:password
Re: [ ttyd][ 1.6.3.0 ] Share your terminal over the web
added x86 version
added arm version (to test)
Pavulon
Post by Pavulon »
Arm version works great.
Testing on my mobile for now 🙂
Thank you
F2-210
arqweryon
Post by arqweryon »
Hello! Will there be a TOS5 compatible package?
Thank you for your hard work!
It will be
added TOS5 version
topo01
Germany
Re: [ ttyd] Share your terminal over the web
Post by topo01 »
Hi
I can't run Docker commands in ttyd.
Apparently there are some paths missing in the PATH variable. If I add
/Volume1/@apps/DockerEngine/dockerd/bin:
I can use Docker commands alright.
However, this is not persistent. How can I make it persistent? Can I add it somehow in the configuration file?
Otherwise ttyd is working great! Thanks to OutkastM! 🙏
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
download and install the latest version
topo01
Germany
Post by topo01 »
:D ! AWESOME ! :D
Thank you so much!
I see you have added all paths under /Volume1/@app.
Great work!
