Poor D8 performance
bigpal
Poor D8 performance
Post by bigpal »
I've had poor performance from a new D8 since the time I purchased it. I didn't know how poor it was until I started troubleshooting REALLY bad forensic processing times. Turns out it's performing like a single spinning disk, or worse. I updated RAID drivers and TB software. There is no updated BIOS for the RAID controller, nor a firmware update for the D8. I've also tried moving the TB controller between slots and different cables.
What steps can I take to figure this out?
Re: Poor D8 performance
May I know how many drives you installed in D8? what kind of drives they are? did you set any raid configuration?
bigpal
Post by bigpal »
I have eight drives installed, they are Barracuda 6TB 5400RPM 256MB Cache (ST6000DM003) I have the system set up in a RAID 5 configuration, 64K block size, 512B sector size. All disks reporting no issues.
bigpal
Post by bigpal »
I should add, when I conduct large file transfers to another system over the network (10GBe ethernet), it will copy between 400-600MBps. When I copy or delete a lot of smaller files, the performance degrades significantly.
bigpal
Post by bigpal »
In testing, the performance does indeed drop when copying small files. This is a read operation from the D8 to another TB array. Copying larger files shows excellent performance, over 500MBps. These files are mostly eml files, json, xmls, etc. Does anyone else experience this on their array?
This is a normal situation in real world. speed will drop a lot when copying small files.
