F4-210 - mount external usb harddrive?
julienb
Post by julienb »
Is there a way to mount an external USB drive (plugged in the NAS) to the windows hard drive list in file explorer like you would your internal NAS storage?
thanks!
TMAY
Re: F4-210 - mount external usb harddrive?
Post by TMAY »
Hi, after inserting the USB device on the nas, there will be a corresponding folder, you can also use the way you use SMB access
