WIFI and LAN access
Winzergasse
WIFI and LAN access
Post by Winzergasse »
Dear All,
Thank you for the NAS F5-221 with ID tnas-2cc797.
I have a Fritz box 7490 and would connect it via WIFI to the WLAN to most computers and wia LAN to a single Windows 10 computer
WIFI seems to work ok on the dongle. But when I disconnect the LAN cable, it does not go via WLAN to the rest of the Network.
After some Hours I tried the ssh interface to check the Routing and to update the Default route to WIFI
[admin@TNAS-2CC797 etc]$ ip route show
default via 192.168.178.1 dev eth1 src 192.168.178.21
169.254.0.0/16 dev eth0 scope link src 169.254.254.8
192.168.178.0/24 dev eth1 scope link src 192.168.178.21
239.0.0.0/8 dev eth1 scope link
[admin@TNAS-2CC797 etc]$ ip route del 192.168.178.0/24
ip: RTNETLINK answers: Operation not permitted
[admin@TNAS-2CC797 etc]$ ip route replace 192.168.178.0/24 dev wlan0
But I am not successfull.
Changing the order via
Network Services => Network => Service sequence
did not help either
Any hint how to allow Routing via WIFI?
Regards
Winzergasse
Re: WIFI and LAN access
Please advise the detailed model information of your dongle and chipset. Please be noted that TNAS only supports a USB Wi-Fi adapter with RTL8812AU chipset.
Is it showing that the USB WiFi dongle is connected when it's plugged to the TNAS?
Return to “Network”
