Unable to expand storage pool after RAID migration
mwarney
Post by mwarney »
Happy New Year,
I recently added drives and migrated from RAID 1 (with two 6TB drives) to RAID 5 (with four 6 TB drives). Everything went smoothly and all is showing as "good." But I am unable to increase the volume size to add the available capacity. I go into volume,edit, and add the free capacity, click confirm, and the little "processing spin wheel" appears as though it is completing the command. But when it is finished, I am left with the same as it was before (showing the available capacity and no increased storage). There are no errors anywhere and everything acts as though it is functioning normal. But I am still left with the original capacity as before. Any suggestions?
Thanks!
mwa
Re: Unable to expand storage pool after RAID migration
You can refer to the following solution: viewtopic.php?f=79&t=2342
