TNAS F5-221 shuts down on its own when copying files
For the 3rd day in a row, my TNAS F5-221 shuts down while I am copying files into it from a Network client.
I am copying using Nextcloud (okm) which is running on the TerraMaster.
Just before the device goes down, I do get repeated CPU Utilization has exceeded 90% messages.
I am getting very disappointed with this situation. Any help diagnosing and hopefully fixing this will be welcome, as with this version of linux, I am not even sure where to begin checking log files.
Re: TNAS F5-221 shuts down on its own when copying files
May i know which TOS version running in your TNAS?
Please also check if the fan is working properly, are your hard drives overheating? If you do not copy data, the device will not shut down by itself?
The version is 4.2.18-2110301149 (I have only had the machine for less than a month).
See screenshot on fan settings. I am not really sure if the fan is really coming on or now, the machine is generally quiet and I am not always in the same room as it.
When you make a copy next time, please check the fan speed and hard drive temp from TOS > Control panel > Hardware information.
Is there a log I can look at to show me what happened last time?
If there is a configuration issue or, even worse, a defect with the fan, I would like to know now.
Hi! If you do not copy data, will the device automatically shut down?
No, this has only happened when I was uploading significant amounts of data to my Nextcloud server onto a RAID1 8TB Ironwolf setup.
Hi! You can pay attention to the temperature of the HDD when copying the files next time.
For TOS 4.2.18, in the fan smart mode, the device will automatically shut down when the hard disk temperature reaches 70°C. You can set the fan working mode to another mode.
{L_BUTTON_AT}sanctimon
are you using only 2 HDD's or why do you use Raid1? You could with 5 disks use a Raid 5 with one HDD failure but the most saving space. Or a a Raid 6 with the possibility of 2 HDD's failure at the same time but less space possibility. And both are faster than a Raid 1!
To protect your data, the system is set to auto shut down if your hard drive remains a long period of overheating when it is over 70 degrees celsius.
please check if tnas fan working normally and your drives overheat during data copying. Please also check if the temperature of your drives presents a correct value, some drives' temperature does not show in a correct location so that the system fails to read the correct temperature value, especially some SSDs. All above may lead to your tnas shutdown improperly.
