Download image
Discussion about Docker
Roccia7
Italy
Download image
Post by Roccia7 »
Hi, i have T Nas F 2-220 with TOS 4.2.18. When i try to download an image i receive a message that tell me only "Error". Wich could be the problem?
TNAS F2-220
TOS 5.0.176
TMAY
Re: Download image
Post by TMAY »
Hi, please check your network, if the network is okay, download from another mirror source to see if it works
Roccia7
Italy
Re: Download image
Post by Roccia7 »
TMAY wrote: ↑19 Dec 2021, 11:54 Hi, please check your network, if the network is okay, download from another mirror source to see if it works
Thanks for your replay. My network is ok, works great with other apps. I also changed the source, uninstalled and reinstalled docker, but is always the same. I also deleted all, maybe, files related to docker
TNAS F2-220
TOS 5.0.176
TMAY
Re: Download image
Post by TMAY »
Okay, please contact our technical team to troubleshoot the problem for you
Roccia7
Italy
Re: Download image
Post by Roccia7 »
I finally made it! I found a simply solution, i don't know if it is a TOS bug or not, but i used ssh command tu download an image and that image was downloaded. So i tried to download an image via docker app and it works! I had no strange error
TNAS F2-220
TOS 5.0.176
Re: Download image
In this case, you may need to try to reisntall Docker or TOS.
Roccia7
Italy
Re: Download image
Post by Roccia7 »
TMzethar wrote: ↑28 Dec 2021, 16:08 In this case, you may need to try to reisntall Docker or TOS.
Sorry, but... Maybe is better to read all messages
TNAS F2-220
TOS 5.0.176
Re: Download image
{L_BUTTON_AT}Roccia7
Sorry, I'm glad you solved it.
Return to “Docker”
