OpenVPN (client) bug in TOS
MooieBoot
Post by MooieBoot »
When using OpenVPN client through TOS, the auth file is stored in /tmp:
auth-user-pass /tmp/openPass
Which isn't available so your VPN will not connect but time-out in TOS once you press connect.
You need to create a seperate file with
user
pass
Store it in your home directory for example, then adjust the config file in /etc/openvpn/user and point it to the right file.
Then it will connect
Re: OpenVPN (client) bug in TOS
How many times have you connected and the display timed out? The system will read the auth file information and write it into the configuration file and then delete it.
Return to “Network”
