What is the file "aaaa" which keeps appearing?
REBELinBLUE
Post by REBELinBLUE »
In the public folder there is a file called "aaaa" which keeps reappearing, does anyone know what it is? I have only found one other mention of it using the forum search.
Re: What is the file "aaaa" which keeps appearing?
did you set the public folder to be a cloud drive sync folder? what happens if you delete it?
REBELinBLUE
Nope, not synced. If i delete the file it reappears. The content of the file is
路径=0/appdata   a=0
路径=0/backup   a=0
路径=0/media   a=0
路径=0/public   a=0
路径=0/appdata/docker   a=0
路径=0/media/#recycle   a=0
路径=0/media/Downloads   a=0
路径=0/media/Movies   a=0
路径=0/media/Music   a=0
路径=0/media/TV   a=0
路径=0/media/TV   a=0
路径=0/media/_un   a=0
路径=0/public/aaaa   a=0
路径=0/media/TV   a=0
路径=0/media/TV   a=0
路径=0/media/_un   a=0
路径=0/appdata   a=0
路径=0/backup   a=0
路径=0/media   a=0
路径=0/public   a=0
路径=0/stuff   a=0
路径=0/backup/#recycle   a=0
路径=0/backup/dropbox   a=0
sianderson
Post by sianderson »
REBELinBLUE wrote: ↑05 Dec 2021, 08:54 In the public folder there is a file called "aaaa" which keeps reappearing, does anyone know what it is? I have only found one other mention of it using the forum search.
i believe it is related to one drive sync, would that make sense? the contents of your file lists dropbox so do you use dropbox sync on the nas drive?
i have this file, and it contains the folder names of what i have set to sync, if i delete this file and then go into the one drive sync program and click on tasks manager it then creates the file which lists the folders i have set to backup
F2-424 TOS 7.0.1278
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
REBELinBLUE
Interesting, I do use dropbox sync but not one drive. Strangely it hasn't reappeared since I removed it yesterday and the only difference is I removed transmission... would seem to be a bit weird for it to be to do with that but then the rssseeds folder next to it definitely did seem to be. Will have to play around more
{L_BUTTON_AT}REBELinBLUE
would you email the aaaa file to our tech team so that we can verify where the file comes from?
REBELinBLUE
It hasn't reappeared again since I last deleted it, will have to play around and see if I can cause it to be recreated. I reinstalled transmission again to see if it was that but it's not
REBELinBLUE
{L_BUTTON_AT}TMroy
today it has re-appeared, zipped up and attached the file
Thank you! we will verify and let you know as soon as possible.
By the way, did you install any backup app on your tnas?
Hardfecx
Post by Hardfecx »
Well, it shows exactly where it's from: everything from dropbox...
路径=0/backup/rpi/sonarr/logs/sonarr.txt
路径=0/backup/dropbox/Apps
路径=0/backup/dropbox/Apps/Jumbo/facebook a=0
路径=0/backup/dropbox/Apps/Jumbo/twitter a=0
路径=0/backup/dropbox/Apps/Jumbo/twitter/media a=0
路径=0/backup/dropbox/Apps/Jumbo/twitter/tweets a=0
路径=0/backup/dropbox/Apps/Jumbo/twitter/media/003cff2b3a22a5eb6902c94a8afbe43ccbbbca0fb2ba5363e5fdc7d43f6f8e27.jpg a=0
路径=0/backup/dropbox/Apps/Jumbo/twitter/media/003e538ee87c97ab8d0710f74890e75b70181e60381960ce47cec7eaea218c83.jpg a=0
路径=0/backup/dropbox/Apps/Jumbo/twitter/tweets/1621104968_1393641364135501833.json a=0
Return to “File Services”
