Docker won't start
Discussion about Docker
pristis
Docker won't start
Post by pristis »
Hello!
Today I buy F2-210 NAS and I just install Docker. Unfortunately, after install and press START button, nothing happens. There are docker logs:
https://pastebin.com/09S2LmAR
I will be thankful if someone help me.
Best regards,
Martin St.
Martin St.
Re: Docker won't start
Hi! Please try to uninstall the Docker and install it again.
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
{L_BUTTON_AT}pristis
Have you updated the OS to latest version? Also have you ensured Docker is latest version?
pristis
Post by pristis »
Hello everybody! The NAS was updated to the latest version. Also, uninstall and install again of Docker doesn't help.
Charlie_Croker wrote: 04 Dec 2021, 07:55 Have you updated the OS to latest version? Also have you ensured Docker is latest version?
TMSupport wrote: 03 Dec 2021, 17:55 Hi! Please try to uninstall the Docker and install it again.
However, the problem was solved, when I reset the unit and reinstall the TOS. During the reinstallation I saw text with red font to update kernel, so after that Docker works.
Martin St.
Return to “Docker”
