[ ZeroTier ] Securely connect any device, anywhere
About: https://www.zerotier.com/
Category: Utility
Applicable models: x.64 series, armv8 series
Applicable TOS5: 5.0.129 or later versions
App download: https://tmnascommunity.eu/download/zerotier
http(s)://yournasip:port/modules/ZeroTier/www
About
Connect team members from anywhere in the world on any device.
ZeroTier creates secure networks between on-premise, cloud, desktop, and mobile devices.
ZeroTier combines the capabilities of VPN and SD-WAN, simplifying network management.
Enjoy flexibility while avoiding costly hardware vendor lock in.
Re: [ ZeroTier ][ 1.8.3.0 ] Securely connect any device, anywhere
added initial version
MooieBoot
Post by MooieBoot »
Hi, thanks for your effort!
Using the web module page, I'm unable to start the service, also though commandline I can't start the service:
sudo service zerotier-one start
>zerotier-one not exists
Without the service starting, I'm unable to start zerotier and daemonize it:
sudo zerotier-one -d
> zerotier-one: fatal error: authtoken.secret could not be written
Without zerotier-one started I'm unable to join any networks:
sudo zerotier-cli join xxxxxxxxxxx
> zerotier-cli: missing port and zerotier-one.port not found in /var/lib/zerotier-one
Is is possible to integrate zerotier-one as a service on TOS?
dowload again the app, i made some changes.
The daemon start automatically and it create your address, you can check this in the WebUI
From CLI you just need to login the network if you want
[administrator@TNAS-xxx ~]$ sudo zerotier-cli join xxxxxxxxxxxxxxxx
Password:
200 join OK
MooieBoot
Post by MooieBoot »
Hi, thanks for the update!
A reboot of the NAS is needed after installation for the service to start/initalize.
A LAN connection is set to "Use as default Gateway" to retain internet connection
However it doesn't seem to work. ZeroTier gets an ipv6 address when I check through cli (ifconfig) and not an ipv4 (which I manually assigned it thourh zerotier), will try to see if I can fix and report back here.
MooieBoot
Post by MooieBoot »
After joining through CLI, the service needs to be stopped and started through the app icon.
Now TOS is accesable through the provied ipv4 address from zerotier
Also make sure you disable "Allow Telnet / SSH only within the local network" if you would like to access your TNAS through SSH and zerotier.
Many thanks for your hard work @outkastm !
MooieBoot
Post by MooieBoot »
After a reboot, the interface is completely gone (using ifconfig to check) so no IP can't be assigned anymore.
MooieBoot
Post by MooieBoot »
After a reboot, package needs to be removed and reinstalled, reconfigured and then it's working again.
This is not practical, can you adjust the startup script?
Will have a look, I didn't test it with reboot.
The config are saved on the default path /var/lib/ZeroTier-one but maybe the TOS is reseting this folder on reboot.
I will adapt it to save the files on /mnt/appdata/MOD_CONFIG/ZeroTier
Re: [ ZeroTier ][ 1.8.3.1 ] Securely connect any device, anywhere
up to 1.8.3.1
fixed the issue that the config is deleted after NAS is rebooted
