Emule and Calibre
claudiocarli
Emule and Calibre
Post by claudiocarli »
Good morning.
Two apps fundamental in a NAS are Emule (for p2p downloads) and Calibre (The best ebook manager in the world!).
It is possible to implements these two in TOS?
Thank you very much.
powerQ
Singapore
Re: Emule and Calibre
Post by powerQ »
eMule is a p2p download application for Windows OS, the org did not release any verison for linux untill now.
yorch
Post by yorch »
emule exists in synology and qnap, therefore, there is some version or way to configure emule over nas / linux
F2-221
qBittorrent for TOS will be online soon. I think this is what you need.
skap
Post by skap »
the program you looking for is called amule. is like emule but for linux systems
Eclisse72
Post by Eclisse72 »
TMroy wrote: ↑07 May 2020, 18:34 qBittorrent for TOS will be online soon. I think this is what you need.
in
No, to connect to edonkey network you need amule
This is lack of amule is really annoying... Just bought a F2-221 and already miss my old Zyxel...
eulero
Italy
Post by eulero »
Ciao all,
there are news about amule for F2-422 ?
It is the only Intel NAS doesn't offer amule ......
EU :x
Current System:
F2-422 - 4TB storage
TOS- 7.0.0333
infoaliste
Spain
Post by infoaliste »
Hi, I have managed to install emule on my F2-221. TOS 4.2.06 If you want to try these are the steps I have followed:
First, I installed Docker from the TOS application installer.
Then I log in SSH as root and execute the following command to install the container:
docker run -p 4711:4711 -p 23732:23732 -p 23733:23733 -v emule_data:/data --name emule reimashi/emule
After a couple of minutes, emule is ready and we can open the browser and manage emule through the IP of your NAS port 4711 (http://yournasip:4711)
Password: admin
You can now leave the SSH session.
If you want to pause the container, log back into SSH and run the following command:
docker pause emule
To reactivate it:
docker unpause emule
Remember that for emule to work properly you must open the following ports on your router:
23732 TCP
23733 UDP
If you want to manage emule from outside your local network you must also open port 4711
In my installation, I find the downloads in the following route:
/mnt/md0/appdata/docker/volumes/emule_data/_data/download
This path may change in your installation depending on the configuration of your storage system
More information about the emule container installed:
https://github.com/tokkenno/emule-docker
claudiocarli
Hi all,
can you tell me how can I share my folders with this tokkenno emule docker version?
infoaliste
Spain
As far as I know, the shared folder is the same one where the downloads are made: ...emule_data/_data/download.
I don't know if more folders can be added for sharing
