[ KernelModules ] Kernel module USB drivers
About: Additional USB drivers to TOS
Category: Tools
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.1 or later versions
Applicable TOS6: 6.0.420 or later versions
App download: https://tmnascommunity.eu/download/kernelmodules
TOS5&TOS6 Click on Support & Help from app description inside the App Center
This app will add additional USB drivers to be able to use adapters like Zigbee dongles, Zwave dongles, USBtoSerial, Bluetooth dongles, etc.
Use these kernel modules on your own risk !!!
drivers included:
btbcm.ko
btintel.ko
btrtl.ko
btusb.ko
cdc-acm.ko
ch341.ko
cp210x.ko
f81232.ko
f81534.ko
ftdi_sio.ko
garmin_gps.ko
ipw.ko
ir-usb.ko
mxuport.ko
navman.ko
option.ko
oti6858.ko
pl2303.ko
qcserial.ko
sierra.ko
spcp8x5.ko
symbolserial.ko
ti_usb_3410_5052.ko
usb_debug.ko
usblp.ko
usbserial.ko
usb-serial-simple.ko
usb_wwan.ko
[root@TNAS-xxx ~]# ls -l /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Nov 24 08:48 /dev/ttyACM0
[root@TNAS-xxx ~]# ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 Nov 24 08:49 /dev/ttyUSB0
[root@TNAS-xxx ~]# ls -l /dev/serial/by-id
total 0
lrwxrwxrwx 1 root root 13 Nov 24 08:49 usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 Nov 24 08:48 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001938DAC1-if00 -> ../../ttyACM0
Re: [ KernelModules ][ 1.00.00 ] Kernel module drivers
added initial version
franckyvrac
Re: [ KernelModules ][ 1.00.00 ] Kernel module USB drivers
Post by franckyvrac »
Can we have ARM version ?
Sorry not possible, i don't have and arm NAS to test them
unixtall
Post by unixtall »
Is it valid for TOS 5? I have an error installing manually: Error! The file is incorrect and cannot be installed
Not valid for TOS5 and i can't port it yet.
I'm waiting some info from TM.
unixtall
Post by unixtall »
I tried to compile the driver cdc_acm with the kernel 4.19.165 i have downloaded. But its seems the kernel which is installed in terramaster is modified. And i cannot load the driver. If the support give us the kernel headers, we could compile the driver without problem i think.
When i saw your post, i was very happy. Thanks for your effort. We will wait to terramaster response.
ramutis
Post by ramutis »
Any news on these drivers? I have sonoff zigbee dongle and started my home automation project, but not possible integrate into homeassistant. I have T2-F423 with TOS 5.
Maybe there are other solutions for this integration?
Regards,
Ramutis
unixtall
Post by unixtall »
ramutis wrote: 23 Feb 2023, 03:04 Hello,
Regards,
Ramutis
The only solution is use the dongle in another device, like raspberry. Its a pitty to can not use in the own NAS.
Re: [ KernelModules ] Kernel module USB drivers
added TOS5.1 drivers
