Configure innodb variable
Using Web Server, PHP, MySQL, MariaDB.
matt_hds
Post by matt_hds »
I would need to change the Variable 'innodb_log_file_size' in my SQLMariaDB server installed on F5-422".
As I was not able to find the .ini or .cnf file : Could you please tell me where it is located? in the appdata repository?
I tried to use command line:
SET GLOBAL innodb_log_file_size = "100663296";
SET innodb_log_file_size = "100663296";
but It returns: (1238): Variable 'innodb_log_file_size' is a read only variable.
Finaly, if I stop the server, I don't know how change the server variable then restart it.
Any help is welcome;
Many thanks,
Re: Configure innodb variable
Hi!
Did you write the variable 'innodb_log_file_size' yourself? We could not find the variable. Maybe in /etc/mysql/my.cnf, you can try to check it.
matt_hds
Post by matt_hds »
Thanks for your reply,
Accessing the "/etc/mysql/my.cnf" via a ssh connection enabled to edit the file as desired.
Steps are as follow:
1 stop the server (application/Mariadb stop)
2 edit the file and add the desired values to use when starting the server as an example adding these 2 lines:
innodb_log_file_size = 1GB
max_allowed_packet = 1GB
note: use the command sudo to edit the file to have the good rights.
3 start the server
4 check the variables are well settled by entering the server and then reading the variables (by default these variables are indeed already defined to small values).
Hope it might help.
Return to “Web Server/PHP/MySQL/MariaDB”
