[ Lychee ][ 4.4.0.1 ] A great looking and easy-to-use photo-management-system
About: https://lycheeorg.github.io
Category:
Last version: 4.4.0.1
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
App download: https://bit.ly/387bhLY
Required packages:
apache24 > 2.4.51.1
PHP80 > 8.0.19.0
http(s)://yournasip:port/modules/Lychee/www
About
Self-hosted photo-management done right
Lychee is a free photo-management tool, which runs on your server or web-space. Upload, manage and share photos like from a native application. Lychee comes with everything you need and all your photos are stored securely.
Managing your photos has never been easier. Upload, move, rename, describe, delete or search your photos in seconds. All in one place, right from your browser.
Sharing like it should be. One click and every photo and album is ready for the public. You can also protect albums with passwords if you want. It's under your control.
Look at all your images in full-screen mode, navigate forward and backward by using your keyboard or let others enjoy your photos by making them public.
Armitage
Re: [ Lychee ][ 4.3.4.0 ] A great looking and easy-to-use photo-management-system
Post by Armitage »
Hi Outkastm,
Thank you for the post, can you direct me to a resource that explains how to set up an sql database on my terramaster NAS.
The installation of lychee is is telling me: Lychee does not create the database.
1 - Manually create your database and then enter the sql details bellow.
I'd be most obliged if you could give me a pointer.
Regards,
Armitage
Cash
Re: [ Lychee ][ 4.4.0.1 ] A great looking and easy-to-use photo-management-system
Post by Cash »
Installed the Apache, PHP and Lychee
Installed MariaDB
Configured the DB info
Host
Port
username
password
When I click on the link I get a server error 500
../13143/public/
I check the logs and I dont see server error 500. What can I do?
You have also the PHP80 app installed as described on the first post ?
what does the WebUI app says, Lychee is running ?
wayneeden
Post by wayneeden »
{L_BUTTON_AT}outkastm
Lychee is stopped.
Autostart on boot is Enabled
installed version is 4.4.0.1
php80 & apache24 had been installed
