i am using the newest version manual instal tpk from Plex Version 1.25.0.5246 but in the app install screen it shows the old version of plex,
when i checked my version this morning it shows that the old version had been reinstalled.
i have again uploaded the new tpk from Plex
and will keep an eye on it, but do you know if the NAS will downgrade it ?
PLEX DOWNGRADED TO OLD VERSION
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
Re: PLEX DOWNGRADED TO OLD VERSION
restart your Nas and have a look if the version is downgraded again.
I have a it set to power down each evening so I’ll check tomorrow
@deejc
I noticed the same thing but hadn't checked until now. I think the app screen in TOS is just showing what version of Plex TOS will install if you click the update button. After moving to the manual TPK from Plex I've completely ignored the installed app section in TOS. I have my server power down every night as well the Plex hasn't reverted back to a previous version. I'd say just ignore that screen. I see the same thing for Emby, it shows a different version in TOS than Emby shows in the setting screen as I've been installing the manual TPK directly from Emby as well.
F2-221 2x 10TB Exos X14
yes i think you are correct, but i had already upgraded to the latest tpk about 2 weeks ago, but checking this morning my version of plex was downgraded to the version shown in the app screen, i upgraded it via tpk again, so will keep an eye on it in the event it downgrades again.
