[ FileRun ] Self-Hosted File Sync and Sharing
About: https://filerun.com
App not available anymore as FileRun doesn't provide anymore a free version
You need to create a MySQL database to be used during installation, uses this guide
To install software updates please follow these steps:
  • Access your FileRun installation and log in as superuser (The default login name of the superuser is “admin” or “superuser”).
  • Open “Control Panel”
  • Go to “System configuration” » “Software update”
About
For Files
No import required
Just like you do with an FTP server, point FileRun to where you keep the files on your server and you will get instant web access to them.
Want to access your files also by FTP, SMB or WebDAV (server included)? No problem. Upload, download or manage the same files.
Guest users
Collaborate with other people without creating accounts for them.
Getting feedback on documents, photos or any type of file has never been this easy.
Send file requests
File requests allow you to collect and receive files from anyone, right into your FileRun user account, with just a link.
File requests are ideal for receiving a large file or collection of files, collecting photos after a special event, and requesting submissions from coworkers and clients.
For Photos
Metadata support
It automatically extracts and index information (Author, Copyright, Date Created, Description, GPS location, Heigh and Width, Tags/Keywords) from JPG, PSD, PSB, DNG, FFF, TIFF files.
It reads Exif, XMP and IPTC and knows exactly which to use.
Automatic import for RAW files from XMP sidecar files is also supported.
Add custom metadata fields for any additional information you would like to attach to the pictures. This information can either be automatically extracted from the files, or manually typed by you.
It shows thumbnails and previews for virtually all image file formats. DNG, CR2, NEF, TIF, 2FR, FFF, RAW, etc, you name it! And it does it on the fly so you don't have to run endless command line scripts. It also caches the thumbnails to instantly show them to you next time and preserve server resources.
Share
Turns folders into online photo galleries with just two clicks. Password protected links with expiration dates, download terms, the whole shebang.
Easy upload
Instantly backup your mobile photos and videos with the free mobile apps.
Sync files from your desktop using the free desktop apps.
Upload files via WebDAV. FileRun comes with its own WebDAV server. No server configuration changes needed.
Or just drag and drop the files (or folders) in your browser. It uploads tons of huge files just like that. No server configuration change required. It even resumes interrupted uploads. Automagically!
For Music
Metadata support
It automatically extracts and index ID3 information (Artist, Title, Album, Duration, Codec) from the files and shows it to you, so you can search and organize your music better.
Add custom metadata fields for any additional information you would like to attach to the audio files. This information can either be automatically extracted from the files, or manually typed by you.
Plays all formats
Plays FLAC (Free Lossless Audio Codec) audio files. In all browsers, without transcoding.
Plays ALAC (Apple Lossless Audio Codec) audio files. In all browsers, without transcoding.
Plays MP3, M4A, AAC, OGG (currently unsupported by IE/Edge) and WEBA.
Share
Turn folders into online play lists with just two clicks. You get an instant PLS file that you can use to stream music to your remote player.
Your music everywhere
Access your music from wherever you are using the free mobile apps.
Sync audio files from your desktop using the free desktop apps.
Access via WebDAV. FileRun comes with its own embedded WebDAV server. No server configuration needed.
Re: [ FileRun ][ 1.00.00 ] Self-Hosted File Sync and Sharing
added initial version
Re: [ FileRun ] Self-Hosted File Sync and Sharing
added TOS5 version
filerun
Post by filerun »
Hi! Nice that you made a FileRun package for this NAS! I have a request though. If you do not plan to update it to the latest version soon, I kindly ask you to remove it or put it offline in the meantime. There are various security issues with the older FileRun versions, we at FileRun would prefer if these versions would not be available, particularly to new users.
Thank you,
FileRun
App is removed as filerun no longer provide a free version
