NAS F5-420 backup to external iSCSI
Discuss understanding the various backup tools available and choosing the one that's right for you
Bernhard.Wuest
Post by Bernhard.Wuest »
Hello, I am sort of new to this and like to get some advise
I would like to backup the content of the F5-420 to another NAS where I created iSCSI connection.
I can connect to it from the terramaster NAS but cant find any program or tool or way how to use it to copy data there.
Any help, links, tips are much appreciated.
If I am on the wrong track with iSCSI which other method is useful
Bernhard
Re: NAS F5-420 backup to external iSCSI
Go to control panel-> storage manager-> virtual disk.
Bernhard.Wuest
Done already see below
Filename NTFS, Size 500GB Connection good.
But how can I copy data from within the NAS to this Drive.
Cant see it anywhere
as soon as you create a virtual disk, you will see such a disk folder in the "File manager" on desktop of TOS. then you can copy your file into this virtual disk folder.
Bernhard.Wuest
Found it. Thanks.
Return to “How to back up? Which one is right for me?”
