TOS 4.2.17 is released for update
TOS 4.2.17 (ARM) Release Notes
Applicable models: F2-210, F4-210.
This update includes following bug fixes for the previous version:
1. Fixed the issue of SSL certificate.
2. Fixed a security vulnerability.
TOS 4.2.17 (X86) Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422
1. Fixed the issue with the SSL certificate of TNAS.LINK.
3. Fixed the fan control issue.
Important Notes
1. This update is only for TOS 4.2.01 or later versions. If your TOS is 4.1.27 or an earlier version, please refer to here.
How to update your TOS?
1. Download the update package: Update package for X86 models; Update package for ARM models;
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
How to re-install your TOS?
1.Download the Installation package: Installation package for X86 models; Installation package for ARM models;
2. Log in to TOS and go to TOS Desktop> Control Panel> General Settings> Update and Restore> Backup and Restore, tick "Backup system configuration", and then click "Apply" to back up your system configuration;
3. Go to TOS Desktop> Control Panel> General Settings> Update and Restore> Restore to Factory Default, tick "Restore to factory default", and then click "Apply"; your system will be erased, but the data on the hard drives will not be deleted;
4. When initializing the installation, please select "Manual Installation" to select the downloaded installation package, and then wait for the installation to complete.
5. After the system installation is complete, log in to TOS and go to TOS desktop> Control Panel> General Settings> Update and Restore> Backup and Restore to restore the system configuration you backed up.
Issue report
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
Important Notes
4. Click "Apply";
Issue report
- Saijin_Naib
Re: TOS 4.2.17 is released for update!
Thanks for the updates and fixes.
Notes:
Reset my HTTPS port
Reset services/services preferences
Reset my SSH settings
Reset Discovery Preference Settings
Reset DoS Prevention preferences
Requests:
Verified download link URL in plain-text in the post
Hash of archives in the post
Notes:
Reset my HTTPS port
Requests:
- sianderson
- Silver Member
upgraded no issues identified so far
F2-424 TOS 7.0.1341
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
f5-422 updated successfully. no problem.
Tried updating my F4-210 and completely destroyed the system. It put the entire drive in read-only mode, cannot even install or uninstall apps. Tried reinstalling the OS but did not fix the problem. My entire NAS is now useless until I can figure out a way to fix it.
installed and restarted normally,
UPS was again set to 7 secs shutdown (was set to low battery before),
AFP is on but the 2 available options are off (were on before),
Region and Language now shows GMT, was IST (yay!!) also on the desktop now shows GMT
Veto files is unticked in the SMB / CIFS page and
the /etc/samba/smb.conf file has been overwritten and again contains "veto files = /desktop" as per this link
viewtopic.php?f=24&t=2382&p=12890&hilit=veto#p12890
this line interferes with backups on my mac and should not exist.
my changes to the LOGIN STYLE page have been reverted
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
- Jac de Lad
Can confirm. Fan on medium drops to 10 rpm after a few minutes. F2-422 *sigh*
{L_BUTTON_AT}"Jac
Hi! Please go to Control panel->system information->hardware information to check devide and disk temperature. When the temperature is lower than 35 °C, the fan will stop.
- Jac de Lad
Device temperature is 31°C, but the hard disk is 46°C. It doesn't make sense to stop the fan if it set to medium. why should it?
{L_BUTTON_AT}"Jac
Thanks for your feedback, we will continue to follow up on this issue.
