Daisy Chained Raid Devices
maylar66
Post by maylar66 »
So I purchased an F5-422 to replace my D5-300. I see that I can attach external USB storage. So I figured why not attach my old D5-300 to one of the USB port on my F5-422? I assumed that would be a standard feature of TOS. If it is I cannot find it. Then I assumed I would need to download a Raid Manager like I needed to do for Windows. However I cannot find a Raid Manager for TOS in order to manage a raid on the attached D5-300.
If I am just missing the configuration please accept my apologies. Otherwise please consider enhancing the produce to allow for daisy chained raid devices.
Re: Daisy Chained Raid Devices
Hi!
TNAS cannot directly manage the RAID array of DAS devices. Thus D5-300 needs to build RAID on the windows first, and then connect to the TNAS through a USB Type-C cable as an external storage device.
you can finish your RAID setup on your computer before you plug it into your TNAS. is that easier?
Hobba
Post by Hobba »
i would love the ability to do this, i would go buy a das tomorrow if i can use it as a second bay of drives for my f5-422
perhaps terramaster can look into implementing this for us :)
