F4-210 Lost Conection to HDD
eroldon
Post by eroldon »
I have a problem whith my NAS. I constantly loosing Connaction to the first HDD, this Problem happens somtimes every day and sometimes everything works fine for weeks. After a reboot the Problem is gone and the NAS works fine again, and i notice that the problem happens mostly on nightime which is anoying because the beeping sound.
Im happy for any suggestions. when there is no solution maybe there is a way to disable the beeping sound permanently, i got a email report of the problem anyway.
THX
Re: F4-210 Lost Conection to HDD
Do you mean that TOS cannot be logged in during use or will it automatically shut down?
If the device automatically shuts down, please check whether the scheduled power on/off plan is created in the hardware and power supply of the TOS control panel, and whether the automatic power-on is turned on.
Which version of TOS are you using?
You can try to change the disk space for use. If the problem still occurs, you need to check your hard disk:
viewtopic.php?f=75&t=1125
eroldon
Post by eroldon »
Thanks for the answer. I dont Lost conection to the System, i can log in and nothing Reboots, it is only the first hard drive in the raid. The System is beeping and shows that HDD one is missing, but when i reboot the HDD it is fine. When i check the Raid there is no problem found.
Im on TOS Version 4.2.15-2107141517
