F5-422 question here about 18tb ST18000NM000J disks
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
kenfrog
Post by kenfrog »
I wanted to ask about the F5-422 and using 5x Seagate Exos X18 18TB Enterprise HDD -(ST18000NM000J). I dont see anything listed on the compatibility sheet or page. I do however see a listing for max array size on this page : https://www.terra-master.com/us/f5-422- ... nu&mid=589
Maximum Internal Raw Storage Capacity 90TB (18TB x 5) (Capacity may vary by RAID types)
Max Single Volume 108TB
The main question is they are not listed as compatible but can they be used or has your team tested these disks in a raid 5x18tb ?
I'm new to the terramaster and searched high and low for the info on the forums but found nothing for these disks.
Re: F5-422 question here about 18tb ST18000NM000J disks
Hi! Nas supports this hard disk, but it is not recommended. Because this hard drive is an enterprise HDD, the noise will be relatively loud.
Return to “Compatibility”
