TNAS F4-210 NFS Questions
wnpaul
Post by wnpaul »
Having recently purchased an F4-210 TNAS I am trying to find my way around it.
Particularly NFS is giving me trouble, as I am trying to use this device with several Linux systems.
I can see no way to export the home directories for NFS, since the function in the GUI is tied to the shared folders, and only shared folders show up in the list. I also cannot find where TOS stores the exports, as /etc/exports and /var/lib/nfs/etab are empty.
I am currently using a workaround where I have bind-mounted /mnt/md0/Users on a shared folder /mnt/md0/home, which I have exported; but since anything I put into /etc/fstab is gone again after a reboot, that is a very unsatisfactory solution.
It is generally frustrating that some files in the OS partition get deleted or restored to some pre-determined state at reboot, while others survive untouched, and that there is no documentation as to which files are persistent and which are not.
I understand the desire to shield and protect novice users from the intricacies of the Linux OS, but there should be a way for more experienced or adventuresome users to override these protections.
Re: TNAS F4-210 NFS Questions
At present, only shared folders can be mounted through NFS to your linux server. This policy will be changed we will update the post here.
Return to “File Services”
