USB Copy doesn't copy sub-folders
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
titanrx8
Post by titanrx8 »
I have 2 x f2-221. The primary server is the active NAS providing storage and backups for the rest of the network devices. The second NAS is the rsync destination for the primary share and daily backups have worked correctly.
Periodically I backup the second NAS to an external USB drive using USB Copy. The task was created to copy the entire share which has a multilevel folder structure. When I check the contents of the USB drive, the entire folder structure is correct but sometimes the subfolders are empty. Some of the trees are correct all the way to the lowest folder, other trees are empty except for the highest level or two.
Is there a way to get every level of the entire share copied? These are my off site backups and need them to be complete.
Thanks.
Hardfecx
Re: USB Copy doesn't copy sub-folders
Post by Hardfecx »
Sorry to ask that, but do you have enough space on the other nas?
It looks like the task is not completed. Have you checked whether your copy task shows completion?
titanrx8
Post by titanrx8 »
TMRyan wrote: ↑20 Oct 2021, 07:44 It looks like the task is not completed. Have you checked whether your copy task shows completion?
The task shows as complete in the log. It has shown as complete every time that I have run the task. I discovered that the folders were empty when I did a comparison of the source and target trees.
TMAY
Post by TMAY »
Hi! Which backup method is used and whether usbcopy is the latest version?
titanrx8
Post by titanrx8 »
Hardfecx wrote: ↑20 Oct 2021, 02:05 Sorry to ask that, but do you have enough space on the other nas?
I'm copying less than 150gb to an empty 6tb drive.
Return to “USB Copy”
