Storage location for snapshots
TerraMaster Snapshot is a disaster recovery tool developed based on the BTRFS file system.
Lausi
Post by Lausi »
is there a possibility to configure see location where snapshots are stored?
Re: Storage location for snapshots
Select the snapshot, click Settings, and then check "allow snapshot visible".
Then you will see the #snapshot in the corresponding shared folder.
gretor
Post by gretor »
However, if the snapshot is backing up an encrypted shared folder, the Show Snapshot selection is not available. Where are the snapshots for these folders ?
With kind regards
gretor
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
It is stored on the same volume as the shared folder, and the snapshot visibility is not available for encrypted shared folders.
gretor
Post by gretor »
So that would mean if it is stored in the same folder, which is encrypted, that you can't access the snapshot when you restart the server and you haven't decrypted the shared folder yet, right ?
It is important to me that the snapshot of the encrypted folder is therefore also encrypted itself.
With kind regards
gretor
TNAS F2-221 - TOS 5
4 GB Ram
{L_BUTTON_AT}gretor
Not the same folder, it is stored in the Snapshot directory of the volume where the shared folder is located. Snapshots of encrypted shared folders cannot be browsed whether the encrypted folder is mounted or not. Before restoring snapshots, you need to unmount the encrypted shared folder.
gretor
Post by gretor »
Ah okay , thanks.
TNAS F2-221 - TOS 5
4 GB Ram
Return to “Snapshot”
