[ OkmSSHD ] OpenSSH server
About : https://www.openssh.com
Applicable models: TerraMaster x.64 series, aarch64 series
Applicable TOS5: 5.0.129 or later versions
Applicable TOS6: 6.0.585 or later versions
App download: https://tmnascommunity.eu/download/okmsshd/
Built with:
OpenSSH v9.9p2
OpenSSL v3.0.2
http(s)://yournasip:port/modules/modname/www
The SSH daemon listenes on port 10022 on all available interfaces - this can be changed through the module configuration page. To login use the use name root along with the administrator password.
This app implements an OpenSSH server and provides a basic status and configuration page that allows to fully configure the server.
OpenSSH is the premier connectivity tool for remote login with the SSH protocol. It encrypts all traffic to eliminate eavesdropping, connection hijacking, and other attacks. In addition, OpenSSH provides a large suite of secure tunneling capabilities, several authentication methods, and sophisticated configuration options.
The OpenSSH suite consists of the following tools:
Remote operations are done using ssh, scp, and sftp.
Key management with ssh-add, ssh-keysign, ssh-keyscan, and ssh-keygen.
The service side consists of sshd, sftp-server, and ssh-agent.
OpenSSH is developed by a few developers of the OpenBSD Project and made available under a BSD-style license.
Re: [ OkmSSHD ][ 1.00.00 ] OpenSSH server
added initial version
MisterXY
Germany
Post by MisterXY »
Hello, is it possible to build it for the ARM version?
Thx.
Re: [ OkmSSHD ][ 1.01.00 ] OpenSSH server
up to 1.01.00 (openssh 9.0p1)
MisterXY wrote: 28 Mar 2022, 23:48 Hello, is it possible to build it for the ARM version?
Thx.
Should be possible :)
added TOS5 version
TM220user
Post by TM220user »
outkastm wrote: 12 Oct 2021, 01:58 Applicable TOS4: 4.1.27 or later versions
Just a quick heads up:
Not sure if it was a glitch on my end, or if the TOS4 folder is actually empty...
Side question: does this disable/bypass the default SSH service that TOS ships with? Or should we do that manually? Or do they not conflict?
TIA
F2-220 (x86 flavored!)
tos4 was empty indeed, added the files back.
It will not interfer with TOS SSH, it use different port.
Also it will not disable TOS SSH, if you want this you have to do it manually from TOS UI
MisterXY
Germany
Re: [ OkmSSHD ] OpenSSH server
Post by MisterXY »
Unfortunately I can't start/activate it under TOS6.
MisterXY
Germany
Post by MisterXY »
@outkastm does OkmSSHD work for you under TOS6?
